13 hours ago, VolatileDoor6 said:
Just wondering if people have had issues running proton on manjaro with a mac computer?
I know very little of mac. Manjaro on the other hand, I've never had any issues with.
Are you running Steam (Runtime)? If it's giving you trouble for some reason, you could try the steam-native-runtime package
sudo pacman -S steam-native-runtime
Maybe that will resolve whatever issue you're dealing with. It's hard to tell without more details about your issue, or logs.
_\---|--------------------------|----------------------------|---/_
_\---|------------------------------------------------------|---------------------------------------------Arch Linux------------------------------------------------|---------------------------------------------------|---/_
_\|Host Specs|/_
|MB: ASUS PRIME-X570 Pro | CPU: AMD Ryzen 9 5950x | RAM: Corsair Vengeance 128GB 3600MHz C18 COOLING: Corsair H150i PRO
GPU: ASUS ROG Strix Nvidia GeForce RTX3080 12GB OC Edition | PSU: Corsair RM850 850W Gold | CASE: Phanteks Eclipse P600 |
PERIPHERALS | KB: Razer Ornata Chroma MOUSE: Redragon M908 | SOUND: Logitech Z-5300e|
CONTROLLER: SONY PS5 DualSense |
|'You can't have no idea how little I care" - Monte Walsh|
(_\|"It just works"|/_)
_\-------------------------------------------------|-------------------------------------------0----------------------------------------------|----------------------------------------------/_
_\---|------------|------------|---/_
https://linustechtips.com/topic/1466418-issues-with-proton/#findComment-15647062
