Meshify 2 case fan hub only has 2 pin cable to join the motherboard sys fan headers so it can't control speed ...??
Solved by Ngamer666,
Oh sorry i found on google, i was using the wrong terms but i will use a fan hub for the power to make it simpler.
It would not allow me to control speed as easy if i use the pump header
EDITED the post question
Featured Topics
SketchNI ·
Posted in Programs, Apps and Websites1 -
FI Fheonix ·
Posted in Storage Devices0 -
Shuyaib007 ·
Posted in Audio1 -
17
Sanedish ·
Posted in Troubleshooting0 -
surjava ·
BytePunk ·
Posted in New Builds and Planning2 -
1
