I helped a friend build a PC a while back and we noticed that we ran out of fan headers and RGB control.
So one-two fans are not currently running.
They want to get a Fan Controller but I don't know what to pick.
When I try and add one in Pc builder it shows none as compatible.
Here is the current build:
https://pcpartpicker.com/list/RFVBY9
Any sugjestions?
Thanks in advance!
https://linustechtips.com/topic/1465890-need-help-with-fan-controller/
you can this fan controller from nzxt which should have good integration with the fans however it only has 3rgb ports so u can plug one into the mobo and it comes with fan slitter cables here is the link:https://nzxt.com/product/rgb-and-fan-controller
Any sugjestions?
Thanks in advance!
If you only need  to connect 1-2 more fans, don't get a fan controller, just get either 1 3way PWM splitter, or 2 2way splitters.
Way cheaper, you don't need to install bloatware, and everything will work exactly as it should.
RGB is a bit more difficult, some RGB can be used with splitters, some can't.
I only see your reply if you @ me.
