Hi
I don't know if i am doing this right with the Forum here ^^' first time using it.
My PC Case is not the best.. and i don't know if this the best Configuration for the Fans? Some tips or Ideas? Is it bad that the Fans on the Bottom blow direct at the Graphics Card fans?
Thanks for your help
https://linustechtips.com/topic/1464915-fan-direction/
Your fan configuration looks relatively sensible. It's fine that the fans in the bottom are pointed at the GPU fans, that's actually the optimal position for them. The front fans are a little more debatable, having them as intakes is the more common approach to them, but there is an argument for doing it the way you did it. If you feel like testing, you could check temps with them both as an intake or an exhaust, but personally I wouldn't bother and just leave it as is, at least until I'm board one day and feel like testing it.
https://linustechtips.com/topic/1464915-fan-direction/#findComment-15634836
No, it's a good configuration.
https://linustechtips.com/topic/1464915-fan-direction/#findComment-15634837
