First Build , need "final check"
Go to solution Solved by brob,
1 hour ago, YamiNoFief said:
As i said, gonna be my first build ill be using it mainly for gaming, but im struggling with choosing a Mainboard
This is what i have so far https://de.pcpartpicker.com/list/zw4fC6
Budget would be up to 2500€ ,
And i would like an mainboard from Asus, just im not sure wich one would be good and eneugh for all the rgb stuff that will be going in my case, so just someone that can tell me, just get this one it has eneugh headers or this is what u need extra and such would be greatly appreciated
Also the Graphics card (Gigabyte) is the one im using now and its gonna be part of the new build until i upgrade it next year so keep in mind if i need something special for like 40 series cards
You shouldn't need any motherboard headers other than USB for Commander CORE and / or Pro.
https://de.pcpartpicker.com/product/RMLFf7/asus-prime-x670-p-atx-am5-motherboard-prime-x670-p has 2 x USB 3.2 gen 1 header (4 ports), 1 x USB 3.2 gen 1 for front panel USB-C, and 2 x USB 2.0 headers (4 ports).
Edited by YamiNoFief
https://linustechtips.com/topic/1464845-first-build-need-final-check/
I would change the case for something cheaper, 200€ is a lot. Geizhals.de should have some options if you play around with the search filters. Same goes for the fans, although that might not be an option if you're set on the RGB thing. I would also consider using an NH-D15 instead of the AIO since it has better reliability and longevity, and you can still mount RGB fans to it. Temps should be similar and some overclocking should be possible with both.
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
There are a few other options when it comes to RGB fans for sure. I have had the non-RGB Arctic F12s for a year or so and they're still great, I can absolutely recommend them.
Trans Rights!
Well so i have been asking for help with the mainboard and you offer advice for anything except that?
