Boot problem after installing new GPU - Need advice.
Solved by TylerD321,
3 minutes ago, centurion_08 said:Already done it, still no post. In the matter of fact, my friend just left with rtx 2060 from gigabyte. His card worked great, 10 startups out 10. I'm already back on my gtx 780 and everything works. It's fucking weird, cuz when 1660 super works it works. It's the matter booting to anything. Which happens only 1 out 4-5 times? I guess i need to return the card.
Yeah if a 2060 works, then the 1660 should work fine. Probably a bad card. Should test it in another machine to confirm.
