Budget (including currency): $5000
Country: USA
Games, programs or workloads that it will be used for: FPS, Sports, Action, Adventure, Reaper, FL Studio, Studio One
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): gaming keyboard and mouse, controller, headset for full immersion with gaming and high fidelity headset for studio, music creation, midi controllers, microphones etc.
Please help me with build options. I would like to game in 4K but if that’s too much then. I’m willing to compromise.
https://linustechtips.com/topic/1463945-dual-use-build-please-help/
For $5k, you should be able to get a 7900X or 7950X and a 6950XT, 32GB of DDR5, and some reasonable SSD's, a 850-1000w PSU, and have money left over. Excellent performance in games, but it can do CPU based rendering easily.
If you aren't an AMD fan, 13900K and 4090 should be easily doable in your budget.
If you seriously need more CPU, you could go Threadripper, but you might be short of a 4090/6950XT.
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
I'm also making music & gaming, my actual rig is doing more than enough for all my music programs & games, i'm in 1440p though so i would probably go for at least a 3090ti for 4K, your budget is large & you can get an amazing configuration out of it, i'm thinking 13900K (less money for same or superior perfs than the 7950X) DDR5 Z790 platform, for the monitor you can go for an Aorus FV43U a good 4K 144hz monitor without totally breaking the bank, peripherals will be on you with your personnal preferences, good luck 🙂
Country: USA
I left some room open for the other parts. I'm not sure if you already have the monitor, but I included one anyways. There's more than enough room in the budget for studio peripherals, accessories, and etc. I would recommend visiting a Guitar Center or somewhere like that for help on that. When I was starting out with streaming and music production, they were able to get me started with that, and they should be able to price match too.
The 2 140mm fans are for the front of the case (mount them as intake fans), and the 3 120mm fans are for the top and back of the case (mount them as exhaust fans). You should also be more than able to use a cheaper 1200W PSU with this build. I went with 1500W so that you can easily upgrade the gpu in the future with no problem.
https://pcpartpicker.com/list/cLYwKp
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($349.00 @ Amazon)
CPU Cooler: Noctua NH-D15S chromax.black 82.51 CFM CPU Cooler  ($99.95 @ Amazon)
Thermal Compound: Noctua NT-H2 10 g Thermal Paste  ($27.43 @ Newegg Sellers)
Motherboard: MSI MAG X570S TOMAHAWK MAX WIFI ATX AM4 Motherboard  ($229.99 @ Amazon)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($89.99 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($219.99 @ Amazon)
Storage: Samsung 870 Evo 2 TB 2.5" Solid State Drive  ($190.61 @ Amazon)
Video Card: MSI GeForce RTX 3090 TI GAMING X TRIO 24G GeForce RTX 3090 Ti 24 GB Video Card  ($1114.99 @ Newegg)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case  ($164.95 @ B&H)
Power Supply: Corsair HX1500i (2022) 1500 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($399.99 @ Best Buy)
Operating System: Microsoft Windows 11 Home Retail - USB 64-bit  ($139.00 @ B&H)
Case Fan: Corsair LL120 43.25 CFM 120 mm Fans 3-Pack  ($89.99 @ Best Buy)
Case Fan: Corsair LL140 51.5 CFM 140 mm Fans 2-Pack  ($71.98 @ Amazon)
Monitor: MSI Optix MAG281URF 27.9" 3840 x 2160 144 Hz Monitor  ($599.99 @ Newegg)
Keyboard: Corsair K68 RGB Wired Gaming Keyboard  ($119.99 @ Amazon)
Mouse: Corsair NIGHTSWORD RGB Wired Optical Mouse  ($68.53 @ Amazon)
Headphones: Corsair VOID RGB ELITE 7.1 Channel  Headset  ($74.99 @ Newegg)
Custom: Corsair MM350 PRO Premium Spill-Proof Cloth Gaming Mouse Pad – Extended XL - Black  ($39.99 @ Amazon)
Custom: CORSAIR iCUE Commander CORE XT, Digital Fan Speed and RGB Lighting Controller  ($59.99 @ Amazon)
$4151.34
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
I typically don't include peripherals as I consider them personal choices. I especially don't suggest earphone to audiophiles 🙂.
My build suggestions are are aimed at creating a quiet running system with space for adding a DAC card if you need one and fast USB 3.2 gen 2x2 ports.
The PSU is a newer model compatible with ATX 3.0 and has native 12VHPWR support.
PCPartPicker Part List
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor  ($449.99 @ Amazon)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($99.95 @ Amazon)
Motherboard: Asus PRIME Z790-A WIFI ATX LGA1700 Motherboard  ($309.99 @ ASUS)
Memory: G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-5600 CL28 Memory  ($419.99 @ Newegg)
Storage: TEAMGROUP MP33 PRO 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($67.98 @ Amazon)
Storage: TEAMGROUP MP34 4 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($349.99 @ Newegg)
Case: Fractal Design Meshify 2 ATX Mid Tower Case  ($165.98 @ Newegg)
Power Supply: Thermaltake Toughpower GF3 TT Premium 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($209.98 @ Newegg Sellers)
Total: $3188.84
Generated by PCPartPicker 2022-10-28 17:17 EDT-0400
Here's how i would spec my machine if i had a 5000$ budget knowing that i do the same as you (music & gaming) 🙂
https://pcpartpicker.com/list/WwYtRv
Note that the prices on the site are hella high, you can get the same build for at least 786$ less if you just get the 4090FE for the real retail price 😉
CPU: Intel Core i9-13900K 3 GHz 24-Core Processor  ($659.99 @ B&H)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler
Motherboard: MSI MAG Z790 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($319.99 @ B&H)
Memory: G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-5600 CL36 Memory  ($324.99 @ Amazon)
Video Card: Gigabyte WINDFORCE GeForce RTX 4090 24 GB Video Card  ($2155.98 @ Amazon)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case  ($158.99 @ Amazon)
Power Supply: MSI A1000G PCIE5 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($199.99 @ B&H)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fan  ($9.94 @ Amazon)
Total: $4059.80
Generated by PCPartPicker 2022-10-29 16:50 EDT-0400
