I assume if vga light is on you have a graphics card. What graphics card and power supply do you have?
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1463819-is-this-a-problem/#findComment-15627054
Only thing that comes to mind for me if you verified bios and drivers are up to date are power delivery. I would double check and maybe reseat cables. I think most people recommend using multiple power cables instead of like 2x8 cables but I’m unfamiliar with what the 4090 is set up for power.
If none of these fix the light I wouldn’t worry about it myself.
Main Gaming Machine
https://linustechtips.com/topic/1463819-is-this-a-problem/#findComment-15627063
Nios and chipset drivers up to date? other than htat I see no problem 🙂
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1463819-is-this-a-problem/#findComment-15627071
