Oddly Low FPS for MW2
Jack Dvorak
I get that the games new, but I'm using mostly low settings, the drivers that are dubbed compatible, and I have 120+ in vanguard, CW, MW2019, but not MW2...
RTX 3060, 32gb ram, ryzen 5 3600x.
Task manager has both at around 60% usage only... cpu temps haven't gone above 37 even on slight overclock (overkill cooling setup) 3060 hasn't gone above 68deg..
Restarted PC and disabled all background activity.
Having a similar problem, with somewhat similar specs...
So far wasnt able to fix this at all. spikes happen in other games too but less often.
Specs:
RTX 3060 ti
Ryzen 7 5800x3d
DDR4 2x16GB DDR4 3600MHz
Specs:
RTX 3060 ti
Ryzen 7 5800x3d
I am not getting spikes it’s more like just consistently shit fps
