Need quick help with GPU cable question
Go to solution Solved by Alinz,
You'll be fine with using the split cable if you are not planning on overclocking, Jayztwocents noticed running an extra cable helps in stabilizing an overclock.
Personally Id reccomend running the extra cable if you can, because the cards are rated for such high wattages.
But for every day using a split cable is fine just fine.
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
