Computer not posting, first build
19 hours ago, johnt said:is the monitor set to the correct input? not sure why it wouldn't post if the fans are spinning. are there any debug LEDs on the mother board that can help direct you to the problem? I can also think of removing the memory sticks and trying one at a time to see if one of the modules is bad. I've also had ram sticks with weird issues in certain slots on the motherboard, and swapping it to another slot fixed it.
Hey thank you for your reply, the monitor is on the correct input and i did try every combination possible of stick placement, the motherboard has 4 leds, the one that says boot stays on green, i even tried swapping out the cables from the power supply and reconnecting everything and it just wont post, im thinking it has to do with the ram sticks compatibilitywise i bought a ddr 4 motherboard and ddr 4 sticks, they arrive later today
