First, is this a good deal for what it comes with?Second, what else do I need? what else do I not need but might be helpful? Also, I want to liquid cool the graphics card and CPU, (GTX 770, amd 8350)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835288005
Can someone make me a list?
Diamond 5 in League :)
https://linustechtips.com/topic/146113-good-liquid-cooling-kit/
Dude this is done for the hadron hydro... no mitx am3+ mobos:  While this may be a good deal for watercooling a hydro but for a regular mid or full tover that won't work well.
I have an ATX am3+ mobo, and why won't it work well?
https://linustechtips.com/topic/146113-good-liquid-cooling-kit/#findComment-1951061
tubeing runs are planned. The pumps performance is optimized for a small loop. The rad choice is because the hadron won't fit anything better and gpu+ cpu on 240mm rad isn't going to give you nice temps/silent operation. Not enough liquid for a bigger loop.. The amount of fittings is planned for the loop inside that tiny case.
https://linustechtips.com/topic/146113-good-liquid-cooling-kit/#findComment-1951077
