3mm LED Quick Question
Go to solution Solved by rjshield,
You can buy the XSPC LEDs they come with the connector to connect them to the power supply
http://shop.xs-pc.com/d/Wired-LEDs_681.html
Sorry for putting this in general discussion, there is no real section for this I don't think, I triple checked so really sorry if there is one.
Onto the question.
Are 3mm LEDs standalone or do they require a power connector? I am talking about the LEDs you put in XSPC CPU/GPU blocks, if that helps.
https://linustechtips.com/topic/146094-3mm-led-quick-question/
Build Log: Monochrome
CPU: Intel Core i5-4670K | Motherboard: Gigabyte GA-Z87MX-D3H | Graphics Card: Asus HD 7970 DirectCU II | RAM: Corsair Vengeance Pro 8GB | PSU: Corsair CXM 600 | Storage: OCZ Vertex 4 128GB,2 Seagate Baracuda 3TB | Case: Corsair 350D Window
https://linustechtips.com/topic/146094-3mm-led-quick-question/#findComment-1950867
Those are for case lighting I believe, not what I'm talking about. Maybe they are :P idk..
https://linustechtips.com/topic/146094-3mm-led-quick-question/#findComment-1950877
