Fan splitter
Go to solution Solved by WiiManic,
It sounds like you want something like this
Not too sure, but I think that is what you where asking for.
Page can't be found.
I'm also not exactly sure what you want.
What connectors would be found on each side of the cable.
https://linustechtips.com/topic/146036-fan-splitter/#findComment-1950001
Don't think you can buy them.
why do you want it like that ?
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/146036-fan-splitter/#findComment-1950031
