"Unable to verify the Deepcool MATREXX 40 MicroATX Mid Tower Case and the Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply are compatible. PCPartPicker does not have sufficient information to know if the power supply will fit."
will they fit?
https://linustechtips.com/topic/1460232-psu-and-case/
Yes it will fit. The case has clearance of 165mm and the PSU is 160mm long.
https://linustechtips.com/topic/1460232-psu-and-case/#findComment-15600005
