my first build
Go to solution Solved by Ithinkeatfeet,
ight im happy now
Are you 100% sure you want to build Micro ATX for your first build? Really dont ever recommend building in such a tiny space for first pc because it can be a nightmare 🙂
https://linustechtips.com/topic/1460089-my-first-build/#findComment-15599192
I just have a small desk and thought a small case would be cheaper
https://linustechtips.com/topic/1460089-my-first-build/#findComment-15599216
Small builds almost always cost a lot more then just a normal sized build lol.
https://linustechtips.com/topic/1460089-my-first-build/#findComment-15599219
This should be better overall
https://pcpartpicker.com/list/vvJWjZ
There's not much of a reason to get previous gen hardware, so the 12400 is going to be a solid choice
Cheap cooler to help with thermals and noise
Good board for the price
Same kit of 32gb ram
2tb m.2 since a 120gb 2.5" ssd is pretty much a waste of money
Good gpu for gaming
Nice case and a good 750 watt psu
https://linustechtips.com/topic/1460089-my-first-build/#findComment-15599237
7 minutes ago, Ithinkeatfeet said:
are there any conflicts with the og list i put up? hardware wise
Make sure you quote or @Ryuikko so I see your replies
I can't quite discern what you're trying to ask here, so I'm assuming you're asking if there's anything wrong with your list in the op. The board is less than ideal for a 10700k for a multitude of reasons, the psu really isn't that good, and a 120gb ssd really isn't worth it, but in theory it should work, though I'm not suggesting in the slightest that you should buy it
https://linustechtips.com/topic/1460089-my-first-build/#findComment-15599254
