Xusb22 driver bluescreens system
Go to solution Solved by ILikeToFlyPlanes,
just not having the controller plugged in on boot fixed it
I have an nvidia shield controller and really like it. The problem is hen I first connected it to my pc, nvidia GeForce stuff installed a driver for it that emulates an Xbox 360 controller. All was fine, it worked. The next day when I started my pc first my lighting by corsair wouldn't change from default to custom and shortly after the pc crashes. This happened every time I started the computer for the first time in that day. The BSOD logs says it's a "driver power state failure" with the xusb22 driver. No hat can I do? I already tried replacing the .sys file with one I downloaded and did "sfc /scannow" but that said all is fine. So hat should I try next?
https://linustechtips.com/topic/1459613-xusb22-driver-bluescreens-system/
  • 2 weeks later...
