haha no
Could you give a proper socket picture? Just to determine if that pin is important or not, if its just a vcc or vss then you can lose a few and still be fine but if its a data pin you are fked
Just flip the board upside down and shake the crap out of it to get that pin off the socket so no shorting occurs
Only thing you can do if its a fked data pin is straight up swap the socket which needs bga rework tools, expensive af for the proper ones and diy makes no sense if its just a 1 time thing only due to cost even if it is <100$ also need to build the thing too
Otherwise boards effectively gone assuming data pin
https://linustechtips.com/topic/1459421-possible-to-fix/#findComment-15594894
21 minutes ago, Somerandomtechyboi said:
haha no
https://linustechtips.com/topic/1459421-possible-to-fix/#findComment-15594908
Now you have yet another reason to get a Z590 board ...🙃
https://linustechtips.com/topic/1459421-possible-to-fix/#findComment-15595004
