So im having a major issue and i think the motherboard is dying but I want to make sure, to start pc specs are
Msi Z490 carbon
32gb corsair vengeance 3000mhz
Intel i5 10400
Msi ventus rtx 3070 2x oc
And corsair rm1000
So i was having some game crashing issues and i restarted my pc now it wont boot, cant even get to bios, the ez debug lights get to vga then the pc cycles, so i tired my gtx 1070 and gtx 1050 both booted into windows but with a error at start saying something about "vbios" it did the same thing with the integrated graphics and i boot cycled a few times on the integrated before fully booting, ive tired enabling and disabling csm, i tired updating bios and CMOS clear still nothing with the 3070 and ik its still good, it booted in my brothers pc but i couldn't really teat past getting to desktop he only has a 500 watt psu so i need some advice
Sorry for any bad spelling or grammar im not great with that plus im on phone atm
https://linustechtips.com/topic/1459276-help-pc-no-post/
Could be the boot drive. Have you tried booting into a portable OS like Ubuntu or Winpe? You can make a portable OS drive using a USB. Otherwise I'd say try reinstalling Windows on the drive or testing it in another computer to rule it out.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1459276-help-pc-no-post/#findComment-15593727
it wouldnt be boot drive if i can get into windows with my other cards, just the 3070 i cant even get into bios with, the pc restarts before theres even anything on the screen
https://linustechtips.com/topic/1459276-help-pc-no-post/#findComment-15593868
49 minutes ago, twocows said:
Did you or your brother or whoever you got the card from flash a custom VBIOS on the GPU? That could potentially cause problems on one computer but not another.
If it's still under warranty, I'd see if you can get a warranty replacement.
No we did not, is basically brand new only had it 2 months. bought brand new to. Im 99% sure the card is fine, im just not what
Is going on, i tried to boot with the integrated 20 mins ago and it wouldn't even post with that without some hiccups but it will with the 1050 and 1070 still. Oh and the cpu is fine no issues with it
https://linustechtips.com/topic/1459276-help-pc-no-post/#findComment-15594012
Maybe try DDU and uninstall all the drivers while you have it posted.
From there on just plug the 3070 in and hope for the best.
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
https://linustechtips.com/topic/1459276-help-pc-no-post/#findComment-15594107
