So I am getting the h440, I'm a complete noob when it comes to building as this will be my first. I'm wondering the best parts to use to liquid cool my system. Potential hardware is as follows. Maximus VI hero, 4670k, 780 Poseidon, undecided on ram but 16gb should do. Also what would a good psu be for that get up with potential for an sli config in the future. EDIT. Also considering the rog pcie ssd for this build as well as some random hdd for mass storage
i7 4770k/Maximus VII Hero/Titan X/ 500gb 850evox2 r0/1000 EVGA G2
https://linustechtips.com/topic/145927-h440-cooling-question/
If you're a complete noob when it comes to building I'd advise against custom watercooling which you will need to do to fit the poseidon into a loop. To be honest you'd be better either saving money and going for a normal 780 or spending a bit extra for the 780ti.
Edit: As for a PSU, try and 850W gold/platinum rated PSU from Seasonic, Silverstone or Corsair, I'd personally recommend the Corsair RM850 but it's up to you of course.
https://linustechtips.com/topic/145927-h440-cooling-question/#findComment-1948664
