i have a weird problem in 1 of my tv that im using as a monitor
it just say no signal when i dont have my gpu driver installed
but when i have a driver installed it work 100% fine
it also just say no signal if i use it on my igpu but it shows up as a display on the resolution screen of windows if i use
my portable 14inch monitor with or without the igpu driver
is there a reason for this?
https://linustechtips.com/topic/1459225-weird-monitortv-problem/
With no driver loaded, windows is probably running at a resolution that is not supported by the TV. Likely 800x600 or 640x480 or some other old low resolution.
i was thinking that to on the gpu i still dont get why in igpu it still dont work
even if i change the resolution of it using a 2nd display
18 minutes ago, Blue4130 said:
What resolution/refresh rate is the IGPU using?
idk its just the igpu of the i5 10400 never really looked at the refresh rate
as for the resolution i set it to the max reso of the tv which is i think 1080p
set it to 1080p and nothing tried 720p and higher than 1080p still nothing
maybe the gpu of the i5 is broken i havent tested with the mini monitor because it only had a dvi port
could the igpu of a cpu break and still be able to use the cpu normally?
You should definitely check out what refresh rate you're trying to run the TV at.
Too high refresh rate = TV blank/black.
