Need help choosing
Solved by Dukesilver27-,
5 minutes ago, bunchy7s said:depends, whats your use?
What's that has to do with anything?
9 minutes ago, ferdzie said:
Asus Dual RX6600xt
($280)
vs
AsRock RX6600XT Challenger OC
($294.83)
*Local shop pricing
Pick whichever you value more, cheaper or better looking. For that much difference and given the choices, I'd go with whichever is cheaper, not much difference other than brand and looks, brand matters quite a bit if your country is not a major market.
For service and RMA, go with a more renown and established brand.
