GPU usage extremely low when running benchmark
Go to solution Solved by Random_Randy,
7 hours ago, emosun said:
so the card works fine and you're just staring at the usage meter only correct?
Turns out task manager is broken and is reporting only 5% usage
6 minutes ago, emosun said:
how are you monitoring gpu usage
Normal Task Manager, HWinfo and AMD Radeon software
11 minutes ago, Dukesilver27- said:
Did you try Furmark? Timespy?
Tried Furmark and still like 5% usage, haven't tried Timespy cause I don't have it.
