fan mm confusing
Solved by Hairless Monkey,
No. CoolerMaser says the max for the top is 240mm:
QuoteRadiator Support - Top 120 / 240mm (35mm max motherboard component height)
Though you could fit two 140mm fans up there:
QuoteFan Support - Top 2x 140mm, 2x 120mm.
The front of the case can fit a 280mm radiator, and up to a 360mm radiator:
QuoteRadiator Support - Front 360mm, 280mm, 240mm, 140mm, 120mm
