hello all, im looking into buying a new mouse, my deathadder is dying out =(
been researching the razer ouroboros and so far liking what ive seen/read.
but wanted to get fellow LTT members input.
what do you all think about this mouse? any other wireless mouse recommendations? pros and cons?
*btw i may get the mouse for $120 brand new.
Motherboard: Asus Maximus VI Hero CPU: Intel i7 4770k (running at 4.4ghz @1.3v, though not stable/validated) CPU Cooler: Noctua NH-D14 (w/ CM Blademaster 3 fan setup) RAMCorsair Vengeance Pro 2x8gb (XMP 2133 CL11 @1.5v) GPU: Asus GTX 770 DirectCUii (OC 1250/8000, pass UnigineHeaven and Furmark) HDD: Samsung 840 120gb (OS and important programs), Seagate Barracuda 1TB (games and downloads), 2x WD Caviar Green 1TB (1 for movies/videos and 1 for music/pictures) PSU: Corsair AX760 Case: Cooler Master Storm Trooper
https://linustechtips.com/topic/145765-razer-ouroboros-input/
just make sure you get the one with the straight laser sensor not the 4G dual sensor
other great wireless options are the G700s and G602
https://linustechtips.com/topic/145765-razer-ouroboros-input/#findComment-1946258
  • 8 months later...
I'm loving my G700s here, it's a lot cheaper than the ouroboros just by a touch as well...
Join the Appleitionist cause! See spoiler below for answers to common questions that shouldn't be common!
Q: Do I have a virus?!
A: If you didn't click a sketchy email, haven't left your computer physically open to attack, haven't downloaded anything sketchy/free, know that your software hasn't been exploited in a new hack, then the answer is: probably not.
Q: What email/VPN should I use?
A: Proton mail and VPN are the best for email and VPNs respectively. (They're free in a good way)
Q: How can I stay anonymous on the (deep/dark) webzz???....
A: By learning how to de-anonymize everyone else; if you can do that, then you know what to do for yourself.
Q: What Linux distro is best for x y z?
A: Lubuntu for things with little processing power, Ubuntu for normal PCs, and if you need to do anything else then it's best if you do the research yourself.
Q: Why is my Linux giving me x y z error?
A: Have you not googled it? Are you sure StackOverflow doesn't have an answer? Does the error tell you what's wrong? If the answer is no to all of those, message me.
https://linustechtips.com/topic/145765-razer-ouroboros-input/#findComment-3841049
Ouroboros is an expensive, wireless gaming mouse with a bad sensor made by Razer. (none of that is good) That's what I think about it. The only wireless gaming mouse I can recommend is the Logitech G602.
There were two versions the standard 8200 dpi laser one is no worse than any other.
As can easily recommend the G700 and G700s as well. The new Naga Epic Chroma from Razer is pretty nice but has a short battery life for me and the fact that it doesn't have a user replaceable standardized battery is rather annoying.
https://linustechtips.com/topic/145765-razer-ouroboros-input/#findComment-3846033
