Mobo : asrock b450 steel legend atx version
cpu : ryzen 5 3500x
ram : hyper x 3200 2x8gb
ssd : adata sx6000 256gb
hdd : seagate barracuda green 2tb
psu : gigabytes superb 720 (old psu from an old pc)
gpu : msi gaming x 570 4gb x 2
So this is a build from 2-3years ago and don’t want to upgrade it, the second gpu was given me by my cousin and wanted to crossfire but the system doesn’t recognise the second gpu. I try to check everything on the internet and could not find it so I need some help.
https://linustechtips.com/topic/1455787-crossfire-issue/
Welcome to the forums!!!
Crossfire is a dead technology unless you're doing computations or high-level graphics (not games), then is not worth it as most games today are dropping SLI/Crossfire support.
Both graphics cards have to be ideally, identical to each other for it to work well. There are other requirements such as being from the same family of GPU architecture and model.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1455787-crossfire-issue/#findComment-15569162
First replace this 15 year old dinosaur. It's not reliable anymore (if it ever was)
With 504w @12v it never can be a 720w PSU.
Cf is mentioned in the spec but CF works terrible on the 4 chipset lanes available for the 2nd GPU. Latency is skyhigh.
Which version of the GPU driver is installed?
https://linustechtips.com/topic/1455787-crossfire-issue/#findComment-15569216
Nvm I think I sorted this out with its manual book. So basically my pcie4 been disabled cause my m.2 in the first slot has been used after I put in my second m.2 slot it registered my gpu. Will change the psu later. Thx btw and the gpu is update via amd software adrenaline edition 22.8.2 ?
https://linustechtips.com/topic/1455787-crossfire-issue/#findComment-15569238
