If you need filesharing capability: FreeNAS with Plex for your DLNA compatibility (Installing Plex Media Server on FreeNAS | Plex Support)
If you're just using it for media, just install Plex.
CPU: Ryzen 7 9700X  | Motherboard: ASROCK B850 Pro-A WIFI | RAM: DDR5-6000 CL30 2x16GB  | GPU: PowerColor Hellhound RX 9070 XT | Case: Fractal North
https://linustechtips.com/topic/1455626-help-setting-up-a-nas/#findComment-15568159
How does the Panasonic bluray player access network files?  Does it support apps like Plex?
How many drives are going to be used?
Desktop: AMD 9800x3d / Asus ROG Crosshair 870e Extreme / Asus ROG Astral 5090 OC / 32GB Corsair Titanium / 4TB & 2TB WD SN850x / Win 11 Pro
Plex/AI:  Intel Ultra 9 285k / Asus Tuf Gaming B860m-Plus / 2 x RTX 4000 ADA / 64GB Kingston Fury / 2 x 4TB Samsung 990 Pro / Win 11 Pro
NAS: Synology DS1821+ (8 x 20TB Seagate x24 ) / Synology RS1221+ (8 x 24TB Seagate x24) / Synology DS923+ (4 x 14TB Seagate)
https://linustechtips.com/topic/1455626-help-setting-up-a-nas/#findComment-15568161
Is Plex free?
https://linustechtips.com/topic/1455626-help-setting-up-a-nas/#findComment-15568165
2 minutes ago, Arminoderso said:
Is Plex free?
For what you are describing, yes: What is Plex? Everything you need to know | Tom's Guide (tomsguide.com)
You won't get the remote streaming options or the android/ios app on the free tier, but if you're just setting it up as an in-home local streaming device to the BR player, it's free.
https://linustechtips.com/topic/1455626-help-setting-up-a-nas/#findComment-15568174
3 minutes ago, Arminoderso said:
Over the router with it's own interface I think
2 drives with 1 main ssd
It sounds like it just pulls files from a network folder, freenas would be the quickest and probably easiest setup.
Plex is free for everything except some of the advanced features like the mobile app or some of the transcoding features but it's unlikely the BluRay player will have that kind of app.
https://pureinfotech.com/setup-network-file-sharing-freenas/
This is probably one of the better easy setup guides, some of the ones you'll run into will be for the more advanced features of freenas which aren't needed for the basic setup of a folder with files. If you go this route the disks will need to be wiped during the setup
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1455626-help-setting-up-a-nas/#findComment-15568179
