Keyboard having connection problems
I have an old das keyboard model s / DASK3MKPROSIL
The problem is that I am getting connection problems
I deduced to the problem to being either the USB plugs or internal cable damage near the USB plugs
Now I don't know what to do, I don't want to go ahead and buy a new keyboard because this one is fine for me right now also a new keyboard can cost a lot of money
I do have another keyboard the problem with that keyboard is that it has clicky switches and I can't bear the sound of them
I was wondering how difficult it might be to fix the cables or should I just buy a new keyboard
Pictures:
https://imgur.com/a/Kd6Cmqn
https://linustechtips.com/topic/1455465-keyboard-having-connection-problems/
