Hi! I bought an MSi 3070 Ti a while back, and it worked amazing with my MSi 1080p display @ 144hz! I then got the latest Nvidia driver (516.94) and when I set 144hz I get this weird artifact at the top of my screen like it can't sync the image or something, I don't know and I have to set the monitor to 120hz in the Windows settings and when I do that it works great! 馃
Are there anyone who have any idea why this is and if there is a fix for this issue? I hope someone could explain what's going on because I have no clue! 馃
https://linustechtips.com/topic/1454561-weird-problem-with-144hz/
HDMI or DP?
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
I'm using a dual monitor setup, the main MSi screen (that has problems) are using DP and the other monitor use HDMI as it doesn't have a Display Port! The setup worked flawlessly until the last Nvidia driver update and it works great still, if I have it set to 120hz as stated! 馃
