im looking for an hdmi switcher for my pc setup. tired of swapping hdmi cords to go between my 32in desk use tv and my 55in 4k for when i want to game in my recliner or bed. but idk whats a decent brand, or whats considered expensive or cheap.
functions id like be 4k60hz capable. very few games i play can be done at 4k so its all 1080 or 1440p 60fps.
at least 2 hdmi out to go between both tvs.
if somehow it can have a remote so i dont even have to get up 😅
id like to stay under 50 if possible but its not a set budget
https://linustechtips.com/topic/1454477-hdmi-switcher-help/
Most of those also do keyboard and mouse too.  You don’t have to use that but though. They’re called kvms. There might be mechanical one for just hdmi monitors though.  I don’t know about the $50 though.
Edited by Bombastinator
https://linustechtips.com/topic/1454477-hdmi-switcher-help/#findComment-15559808
not quite what im looking for. im doing single pc to 2 different displays. i have a bt controller and mouse i use just to swap games with when away from desk
https://linustechtips.com/topic/1454477-hdmi-switcher-help/#findComment-15559813
first one i found thatll work and i can integrate my surround into it as well. this is basically what i was looking for but no idea on quality
Amazon.com: ZPTEK 4K HDMI Matrix Switch 4 X 2,4 in 2 Out Video Switcher Splitter, Optical and LR Audio Outputwith IR Remote Controller,Support 4K@60Hz 3D 18.5Gbps x 3 Data Rate, HDMI 2.0b, HDCP 2.2, MH42-C1 : Electronics
https://linustechtips.com/topic/1454477-hdmi-switcher-help/#findComment-15559817
Yup.  It a 1 to 2 splitter.  Just turn it around.  Notice how I said mechanical kvm
https://linustechtips.com/topic/1454477-hdmi-switcher-help/#findComment-15559855
