Budget (including currency): $1500 (includes monitor)
Country: Australia
Games, programs or workloads that it will be used for: Minecraft, Valorant, rocket league, editing.
I want to play valorant, minecraft, and rocket league at 144-165 hz at 1080p. I am upgrading from a lenovo yoga 11e i3 7th gen with a 10 inch screen. Probably going to buy on black friday. Also suggestions for a good 144-165hz monitor between 23.8 and 27 inches and 1080p.
Intel Core i3-12100F 3.3 GHz Quad-Core Processor $159
Asus PRIME B660M-A WIFI D4 Micro ATX LGA1700 Motherboard $219
Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory $109
Silicon Power A60 1 TB M.2-2280 NVME Solid State Drive $107
ASRock Radeon RX 6600 8 GB Challenger D Video Card $359
Thermaltake Versa H18 MicroATX Mini Tower Case $55
Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply $132
Asus VG258QR 24.5" 1920x1080 165 Hz Monitor $289
Total $1429
Edited by oWhatTheHell
Part list changed slightly
https://linustechtips.com/topic/1453469-first-ever-pc-build/
You should replace the HDD with an SSD, that is really the most important quality of life upgrade of the last decade (pc will feel way faster, boot quickly, games load faster). A modern pc really should not go without one.
https://linustechtips.com/topic/1453469-first-ever-pc-build/#findComment-15552585
Thanks, any recommendations?
https://linustechtips.com/topic/1453469-first-ever-pc-build/#findComment-15552958
Cheapest price/GB For an m.2 SSD.  There are a bunch of little things that can make one better than another and SSD nerds will chew your ear off about it,  but for gaming you’ll never be able to tell the difference outside of how much you spend. They’re all really fast these days, windows will run at the speed of a click and games will boot in seconds.
Memory chips used for SSDs are all made by micron, hynix or samsung (they all make a good working product) so brand doesn’t matter.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1453469-first-ever-pc-build/#findComment-15552965
