Hey everyone, I have this pre-built I bought for me and the kids early this year and it's been a pretty good rig. But I noticed the HDD starting to get a bit full, so I bought another HDD got home and pulled off the cover... Now there is room for another drive and I have some experience working on computers what I found has me lost and wondering what to do. My only idea is to go buy a new power supply and a fan controller and rewire the whole thing. Dose anyone have an easier solution for me? 16619928675183945091013703529508.thumb.jpg.95ea7a95fd0088711f5a30ffbae090a4.jpg
https://linustechtips.com/topic/1452757-pre-built-mess/
Welcome to the forums!
Your HDD would go behind that mess of cables, likely. Check back there, the other side of the case.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1452757-pre-built-mess/#findComment-15547918
You need a bit of patience and some time to rewire the whole thing, by the look of it, there's not much cable management on that case. I'd suggest to find some zip ties/velcro straps/cable ties and do some cable management.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1452757-pre-built-mess/#findComment-15547929
Either you can buy a new PSU and rewire the whole thing, or only rewire the whole thing. Just looks like a case of bad cable management, surely there are more SATA power connectors in that tangle.
Did you also grab a SATA data cable for the HDD to connect to the motherboard?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1452757-pre-built-mess/#findComment-15547934
Yeah I grabbed a sata cable to go with HDD and the company finally got back to me with instructions. Turns out to get to the HDD screws I need to remove the psu and the front panel so it's looking like it might be a bigish job. I do have a 750 watt Corsair psu I just put in my bar computer I might transfer it to this one seeing as I want to get a bigger gpu in the future and it currently only had a 550 in it. These smaller style cases aren't anywhere near as user friendly as what I'm used to. Also thanks for the welcome and help everyone I might be needing a bit as I haven't built computers since the XP days and as much fun as I'm having I am getting stumped at times.
https://linustechtips.com/topic/1452757-pre-built-mess/#findComment-15548185
Make sure to quote us so we can see your responses
No hard drive sleds? Strange, I took this case for something with a bit more of a modern touch but maybe I should have known better given the power supply with ketchup and mustard cables.
If it's not modular, I wouldn't really recommend using it as an upgrade considering it wouldn't change much. And a 550 watt PSU isn't really all that bad considering that's enough watts to run the vast majority of systems.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1452757-pre-built-mess/#findComment-15548428
Ah I figured it out thanks mate. It's been a while since I've done the forum thing too.
It's not and I thought about it and with the limited room in the case I'm thinking modular would be tho only way to tidy it up. As for the hard drive tray I'll upload some pics when I get around to doing it the email I got about it has like 7 steps so it could be an interesting adventure lol.
https://linustechtips.com/topic/1452757-pre-built-mess/#findComment-15548612
