upgrade psu help ??
Go to solution Solved by BiotechBen,
Should be great, looks like you're going to a higher quality PSU as well so power delivery should be more stable
just for curiosity and to gain knowledge
even a 800 watt psu would've worked as long as its above what the system needs right ??
but it would be stupid to get on as it will just cost you more ???
im just guessing am i right ?
https://linustechtips.com/topic/1452513-upgrade-psu-help/#findComment-15545999
A lower wattage quality PSU will always be better than a high wattage dangerous PSU.
Wattage above what is needed is a good way of offsetting future costs when upgrades come along, and it's best practice to budget 20% above what your system can draw at max.
https://linustechtips.com/topic/1452513-upgrade-psu-help/#findComment-15546031
 oh okayt
now im saying like a corsair 550x and a rm850x it would be fine to get both but considering price it would be wiser to get the cheaper one if you system only needs around 400 lets say ? ?
https://linustechtips.com/topic/1452513-upgrade-psu-help/#findComment-15546047
4 hours ago, aryanpall said:
 oh okayt
If you are actively pulling 400w, I'd say a 650 would be a good choice, able to handle momentary spikes, with a 1700 and 1050, you'll be more than fine with a 550w.
https://linustechtips.com/topic/1452513-upgrade-psu-help/#findComment-15546329
