Cable question
By
whysohappy6563
in Displays
in Displays
Solved by Isuck Assimov,
DP 1.4 (which is supporetd by your USB-C 3.2 gen 2 port) should be enough for 165hz at a resolution of 2560 x 1440.
DP 1.2 would technically have too little bandwidth but anything newer can do it.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
