My computer has had its frames capped at 138 recently when in the past it has been capped at 144. My monitor is also rated for 144. This only happens when I have g sync activated though, has anybody had any experience with this issue or has a potential fix for it. It really isn't that big of a deal, it just bothers me a little bit since it doesn't match the monitor refresh rate. Thanks in advance
CPU: I7 10700k
Ram: 16 gb corsair rgb vengeance pro 3200 mhz
PSU: Evga fully modular 750 watt gold rated
Motherboard: Asus TUF gaming b560m plus wifi
Boot Drive: Samsung EVO 970 plus 1 tb ssd, more than half storage left
Storage HDD: Seagate Barracuda 4 tb, more than half storage left
Case: Corsair 220t with 3 Corsair sp 120 front fans
CPU Fan: Cooler Master Hyper 212 RGB Black
OS: Windows 10 Pro
GPU: ASUS TUF Gaming 3060 ti 8 gb
https://linustechtips.com/topic/1450070-nvidia-g-sync-problems/
My suspicion is there’s some slider in some app you jiggled a bit so it’s not quite on max even though it looks like it is.
https://linustechtips.com/topic/1450070-nvidia-g-sync-problems/#findComment-15528923
