Doing a brand new setup and wanted some advice towards what peripherals I should buy.
I have 150 euros and need a keyboard, mouse and mousepad for gaming. Not really picky in terms of, if anything is wireless or not. Generally care about the durability of the product.
I'm using a site called Skroutz: https://www.skroutz.gr/ , so it would mean a lot if you could find something from there!
Thanks in advance!
https://linustechtips.com/topic/1449653-help-me-choose-peripherals/
I like the Logitech G502 as my mouse and I use a Logitech mechanical keyboard.
The Logitech home model mechanical keyboards are about 50~60 USD where as the gaming counterparts are $120+.
The LTT mouse pad exists, but it's up to you on if you want it.
That site says the first two are 110 Euros, so you have 40 euros for a mouse pad which should be plenty.
Keyboard
https://www.skroutz.gr/s/22648298/Logitech-G413-Gaming-Μηχανικό-Πληκτρολόγιο-με-Romer-G-Tactile-διακόπτες-και-Φωτιζόμενα-πλήκτρα-Αγγλικό-US-Ασημί.html?from=featured&product_id=79588585
mouse:
https://www.skroutz.gr/s/16388821/Logitech-G502-Hero-RGB-Gaming-Ποντίκι-16000-DPI-Μαύρο.html
Thanks in advance!
https://www.skroutz.gr/s/28402855/HK-Gaming-GK61-Gaming-Μηχανικό-Πληκτρολόγιο-60-με-Gateron-Brown-διακόπτες-και-RGB-φωτισμό-Αγγλικό-US.html
if non-optical, very good value
you can mod it and add premium switches since its hotswap
6 hours ago, person123456789 said:
I was actually looking at a very similar one to this, so i'm probably going to end choosing this one!
Keyboard
mouse:
I really wanted to buy the ltt mouspad but where I live it costs like 1/2 of the mousepad only to ship it out 😞
Really solid peripherals though. Thank you!
