Fan specs
28 minutes ago, El Pipa said:
Higher air pressure means the fan can push more air through dense radiators, through fins of a cpu cooler that are very close together, basically the fan can deal with obstructions better.
Air flow in CFM means cubic feet per minute of air, it's the amount of air that is moved by the fan. BUT this amount of air is usually calculated without obstructions - even the fan grille that prevents you from shoving your fingers into the fan blades, is an obstruction.
You don't want to replace the fan on your cpu cooler (the tower kind with heatpipes) with a fan that has high CFM but low air pressure, because those thin blades of aluminum will be enough of an obstruction to not move air through the tower cooler and you'll get low performance.
Case fans will usually have a high CFM but low air pressure, as soon as you block them with dust filters and grills their performance decreases.
Fan noise level is how much noise the fan may make at highest speed. A lower value is better.
Sleeve (cheap) bearing and some of those maglev and fluid dynamic bearings fans will be more silent at the same rpm compared to ball bearing fans, but in theory ball bearing fans are more reliable and can run at higher speeds.
