@HoFFNetwork
It doesn't  matter how you set your loop.
Just make sure that you have your reservoir going directly to the pump. To make sure to limit air getting into the pump (that's bad for it)
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/144856-loop-set-up-help/#findComment-1934491
The liquid temps there might be a bit cooler than the rest of the loops, but it doesn't really matter in what order the components of a loop go so long as the reservoir goes to the pump and it is above it. This saves pumps from running dry causing a possible failure,
https://linustechtips.com/topic/144856-loop-set-up-help/#findComment-1934504
@HoFFNetwork
okay but will the water stay cool when it goes thru the res and pump?
https://linustechtips.com/topic/144856-loop-set-up-help/#findComment-1934507
The water temp will stay the same through the whole loop. The water temp will stabilise through the loop.
https://linustechtips.com/topic/144856-loop-set-up-help/#findComment-1934526
ok sweet thanks
No problem  :lol:
https://linustechtips.com/topic/144856-loop-set-up-help/#findComment-1934545
