Budget (including currency): 1,746.14 Euro
Country: Romania
Games, programs or workloads that it will be used for: Gaming, 3D rendering (Majorly Blender) and Autodesk suite (Like AutoCAD, Inventor, 3dsmax, etc.)
At the beginning of last month I started to plan my first PC build.
So the specs are the following:
- NZXT H510 Flow (4 total fans without the RGB)
- NZXT N7 B550 motherboard
- AMD Ryzen 7 5700X
- 2 x Corsair Vengeance RGB RS 16GB DDR4 3200MHz CL16 Dual Channel Kit
- GIGABYTE GeForce RTX 3070 VISION OC LHR 8GB GDDR6 256-bit
- Cooler CPU ARCTIC AC Freezer 34 eSports DUO Grey
- Power Supply Unit SilentiumPC Supremo FM2, 80+ Gold, 650W
- 1x SSD Samsung 980 500GB PCI Express 3.0 x4 M.2 2280
- 1x HDD Seagate BarraCuda 2TB SATA-III 7200RPM 256MB
This is not included in the budget but I have 2x MSI Curved 27'inch monitor, HyperX Keyboard, HyperX headset and a Logitech mouse.
So my questions are the following:
- If the PSU is enough and is supporting the power draw of all the components?
- If the price is ok?
Many thanks in advance.
https://linustechtips.com/topic/1447712-first-pc-build/
12600kf -295€
34 esports duo -43.30€
B660m gaming x- 150€
G.skill aegis 16gb 3200 cl16 -60.50€
Adata xpg 1tb nvme- 93.20€
3070 - 715.51€
P400a digital -113.50€
Corsair rm 750 gold- 129€
Shoud come out to around 1600€ while having better perfromance
https://linustechtips.com/topic/1447712-first-pc-build/#findComment-15511771
