So I currently have an ATX sized rig which I am planning to shrink into an ITX, and I was wondering how good the ALC 898 chipset and if its drivers are good
I currently have a Xonar DG with a Steelseries Sibera v2
I like the driver that came with the xonar, but mostly because I can hear myself when my mic is on.
So my main question is if I should invest in a usb soundcard after I shrink it down.
I've read the that the specs for the realtek chip that its pretty good, but I have no idea about how well their drivers are.
Thanks for any help!
https://linustechtips.com/topic/14477-sound-card-questions/
You don't really need to switch the sound card to a USB one, The DX is pretty small for a soundcard already so it will go well with an ITX build. Plus it the DX sounds so good why would you want to change it for something worse?
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160604
err, well I have the DG, which is their PCI one, and my ITX board only has one PCIe slot?
That's even smaller then the DX. Apologies for the mistake btw.
Are you gonna add a GPU to your build?
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160621
Oh, yes I am
I probably should've mentioned that >.<
Ah then say goodbye to the soundcard :(
The USB soundcard will sound better then the onboard sound but not by a lot.
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160632
I have a Xonar U3 for my laptop (STX in my desktop), In my experience it's dramatically better than onboard sound - but nothing like a real soundcard.
EDIT: Maybe you should look to m-ATX?
Desktop - Custom watercooled R4E/i7 3930k/GTX 780 SLI/32gb 2400mhz DDR3/Xonar STX/OCZ V4 256gb RAID 0/24tb RAID 5
Laptop - Clevo P370EM - i7 3630QM/GTX 680M SLI/8gb 1866mhz DDR3/840 pro 256gb RAID 0/750gb mechanical
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160635
Hmm, I see
Well it's too late for my to switch to m-ATX because I already bought a Prodigy during that NCIX sale xD
Is there any other way to rank sound cards besides their SNR ?
This page says that it has a 104/110 dB snr, while the DG has 103/105 dB
Though I'm not really sure what that means, I know that usually the bigger number is better
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160659
I'd say get a FiiO E10 except you have a headset.  The onboard will be fine, maybe better.
http://nwavguy.blogspot.com/2011/02/sansa-clip-measured.html
http://nwavguy.blogspot.com/2011/02/behringer-uca202-review.html
Here's a couple good example of how best to measure these things.
>$10,000
Maybe one day...
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160828
>$10,000
Maybe one day...
Woah, those are long articles
I guess I'll stick to the onboard then
the itx form factor only has one PCI Express x16 slot
That is correct!
I was wondering though if i should get a usb soundcard instead though
https://linustechtips.com/topic/14477-sound-card-questions/#findComment-160974
