This is my first build and could use some help. If someone could just look through make sure I didn't miss any compatibility issues or if you have some suggestions that could help that would be great. Thanks :)
Case: Cooler Master HAF X
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Motherboard: MSI Z87-G45 Gaming LGA 1150 Intel Z87
http://www.newegg.com/Product/Product.aspx?Item=13-130-693
CPU: Intel Core i5-4670K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
GPU: GTX 770 2gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127741
RAM: G.Skill Trident X Series 16gb+ G.Skill Fans (just because)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231588
http://www.newegg.com/Product/Product.aspx?Item=N82E16835236002
PSU: CORSAIR CSM Series CS550M 550W
Hard Drive: WD Black Series 1tb
Sound Card: Creative Sound Blaster z
CPU Cooler: CORSAIR Hydro Series H55 Quiet Edition Water / Liquid CPU Cooler. 120mm
I am also looking for tips on aesthetics and layout. if anyone find a part that doen't make sense and you have a better option PLEASE tell me.
https://linustechtips.com/topic/144743-my-first-build/
Case: Corsair Obsidian 750D
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139024
GPU: MSI R9 270 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127769
PSU: Silverstone Strider Gold S Series 750w
CPU Cooler: Cooler Master V8 GTS
If this system is for gaming your GPU needs to be vastly upgraded. R9 270 is a very middle of the road card. If you are getting a 4670k I would be thinking around a R9 280X or a GTX 770
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932866
3 things that stick out to me:
You should have bought 2 8GB DIMMS instead of 4 4GB. (Just in case having 32GB become a thing in the future.)
Dat GPU. You should have reallocated your budget to get a better card.
That case is overkill for such a system. The thing is gonna look empty.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932888
@Davsmith4
As @rhawthorne said. The case is a massive (great case). But for that build it's unnecessary. Try for a smaller case, like the 650d Obsidian or similar. The PSU is overkill, also. Anything 500 watts is good. The RAM, sure you said "just because". I would defo go for a cheaper kit like the corsair vengeance. With the money you save, upgrade the GPU to either a GTX 780 or R290.
Honestly, the noticeable affect you will get is from the GPU, while gaming.
Put in a 60BG or 120GB SSD as your boot drive. Honestly the most important thing, after a good GPU. Is to have an SSD. The boot time and overall performance boost from an SSD against a HDD is MASSIVE!
Everything else is fine.
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932906
I notice a lot of people pointing out the size of the case. I know it will look empty but it is the only one i could find in that price range that actually appealed to me. if you know one that looks similar plz tell me.
get a HAF-X it looks even better ,or a define R4, an 800D or a cooler master CM storm scout 2
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932919
Corsair 450d, basically the same but with better airflow
Others to note:
Fractal arc midi
Fractal design define r4
Twitter | Steam |
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932931
Please note I like the PSU as it could allow for upgrades in the future.
it does but if you will run some very high end GPU in dual configuration ,it will handle it yes, but will running at near 90% load ,it's Gold so it should be alright, but for me, i like to give my PSU some 25~30% headroom, so it lasts longer and runs cooler and quieter, it's just me
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932950
Any suggestions? I don't know much about PSU options.
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932965
just get a well branded one Cooler master,corsair ...80+ Gold would be good ,and up the wattage to like 800~850W just to be super sure it will handle it, if you aim to up the Graphics cards config ;)
https://linustechtips.com/topic/144743-my-first-build/#findComment-1932987
Would this one work (i literally have no idea what psu to pick) CORSAIR CSM Series CS550M 550W?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139059
https://linustechtips.com/topic/144743-my-first-build/#findComment-1933011
VERY GOOD ONE ,Corsair is well known to make very good PSUs ,GS Series is also a good choice
https://linustechtips.com/topic/144743-my-first-build/#findComment-1933048
Wow, this is a great forum. 5 minutes and already this many posts and no trolls. I have been watching Linus for a long time and just decided to get an account to his website. Thanks for all the great suggestions :)
it's LTT ,the best out there ;)
https://linustechtips.com/topic/144743-my-first-build/#findComment-1933089
Aesthetic appeal is one of my main concerns.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119236
https://linustechtips.com/topic/144743-my-first-build/#findComment-1933098
if going for a GS 600 fits your budget it would be great ,just to give it some headroom as i saidhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817139023
https://linustechtips.com/topic/144743-my-first-build/#findComment-1933108
