Budget (including currency): $1600AUD
Country: AUS
Games, programs or workloads that it will be used for: 4K 120Hz or 3440x1440 144/120Hz gaming
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($399.00 @ Mwave Australia)
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler
Motherboard: Gigabyte Z690 AORUS PRO DDR4 ATX LGA1700 Motherboard  ($449.00 @ Mwave Australia)
Memory: G.Skill Trident Z Royal 32 GB (4 x 8 GB) DDR4-3200 CL16 Memory
Power Supply: SeaSonic FOCUS Plus Platinum 850 W 80+ Platinum Certified Fully Modular ATX Power Supply
Hi all, I just need some help and some opinions on which GPU would be good for this set up.
I either want to go for a RTX 3080/3080 Ti for Nvidia or RX 6800XT/6900XT for AMD
All Prices are in AUD
Nvidia:
https://www.mwave.com.au/product/gigabyte-geforce-rtx-3080-ti-vision-oc-12gb-video-card-ac44994 - RTX 3080Ti $1500
https://www.mwave.com.au/product/open-box-gigabyte-geforce-rtx-3080-eagle-12gb-video-card-ac55546 - Gigabyte RTX 3080 12gb $1249
https://www.mwave.com.au/product/msi-geforce-rtx-3080-gaming-z-trio-12gb-video-card-lhr-version-ac50839 - MSI RTX 3080 12gb $1379
https://www.mwave.com.au/product/asus-geforce-rtx-rog-strix-3080-oc-12gb-video-card-ac50796 - Asus RTX 3080 12gb $1389
https://www.mwave.com.au/product/gigabyte-geforce-rtx-3080-vision-oc-10gb-video-card-rev-20-ac45704 - Gigabyte RTX 3080 10gb $1259
AMD:
https://www.mwave.com.au/product/gigabyte-radeon-rx-6900-xt-gaming-oc-16gb-video-card-ac41700 - Gigabyte RX 6900XT $999
https://linustechtips.com/topic/1447171-gpu-selection-help/
Country: AUS
Nvidia:
AMD:
I'd go for the 6900XT between those choices, however the 6950XT is even better, are those available?
If you're going to be gaming at higher refresh rates, I also assume you won't be turning on raytracing, as that severely reduces fps. The AMD cards are generally better without raytracing. My choices would be 6950XT > 6900XT > 3080 TI > 6800 XT > 3080
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507482
The 6950XT starts at $1700AUD. It's out of budget and for the performance increase over the 6900XT. Not worth it.
I was having trouble deciding between them because of DLSS, from the look of things, it boosts FPS significantly without any noticeable impact on the graphical fidelity of the games. So basically my question is: Is the extra $500 worth DLSS and Ray tracing?
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507490
AMD has their own DLSS called FSR. Both are indistinguishable from one another and in a way FSR's getting far more support, mostly because it's open source and can be manually modded into a game rather than waiting till devs implement it themselves.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507492
Would you consider second hand GPUs? It might be worth looking into if you have buyer's protection/insurance sort of thing, or transferable warranties.
I'm not Australian, so prices would be converted to AUD, I bought a used Asus TUF RX 6800 XT (less than a year of use) for AUD $1,015 and the new one is AUD $1700ish. With the transferable warranty and 2 years remaining on it, I'd say the price I paid way is more than worth it.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507517
I considered it but the used market is either more expensive than brand new (for AMD) and only about $100AUD ($69USD) cheaper compared to brand new for RTX 3080/3080Ti
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507523
I see, well if you have not decided, going with the RX 6900 XT seems like the best bang for buck, not to mention that it is generally more powerful for non RT games than RTX 3080, unless you really care about raytracing and you feel the extra several hundred is worth it.
Seeing as FSR 2.0 has launched it is close to DLSS, future games would more than likely to implement it into their code, so DLSS might not be such a big advantage anymore.
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507529
So I managed to snag a Sapphire RX 6900 XT Toxic LE for AUD $1035 ($715 USD) Brand new - unopened.
Thanks for the advice all!
https://linustechtips.com/topic/1447171-gpu-selection-help/#findComment-15507926
