Stuck at vga debug led
Go to solution Solved by Hesper,
UPDATE: I tried the gpu on my friend's pc and it works fine. Tried his gpu again on mine, still same.
Decided to buy a new board, works perfectly now. Guess something happened on the PCI-E slot
I was doing some checks on the system (full system scan and sfc), no problems found then I decided to restart the pc. Now it's stuck at the VGA debug led on the mobo. No lights on the led of keyboard and mouse.
I've tried clearing CMOS, 1 ram stick at a time at different slots, used new sata cables, reseated the power cables on the psu and the mobo, checked for damages on the board, reseated the gpu, tried only plugging the gpu, ssd, keyboard and mouse.
 if I plug in the keyboard and mouse while the gpu is unplugged, i think it works because the lights are on and num lock lights are working. If I plug in the gpu, no lights just the debug led for vga.
The specs are
Cpu: ryzen 5 2600
Gpu: zotac rtx 3060
Ram: 2x kingston hyperx 8gb 2666mhz
Psu: seasonic m12ii 620 bronze
Mobo: msi a320m pro vh plus
Os: win11 pro
Sadly, my cpu doesn't have a built in gpu so no display on the motherboard ports.
If this was cause by gpu, any ides what happened? The system was running fine just before I restarted. Kinda makes me regret restarting the system
https://linustechtips.com/topic/1447010-stuck-at-vga-debug-led/
The specs are
Cpu: ryzen 5 2600
Gpu: zotac rtx 3060
Os: win11 pro
Try to clear cmos again. Power off PSU. Remove CMOS battery for 5 min. Might need to remove GPU to get to CMOS battery.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1447010-stuck-at-vga-debug-led/#findComment-15506208
hmm this is a hard one but my guess would be a motherboard issue as greg Salazar on yt had the same issue with a pc he tried to fix and it was the motherboard. try re seating the cpu and if that doesnt work i think it could be the mother board.
https://linustechtips.com/topic/1447010-stuck-at-vga-debug-led/#findComment-15506213
Will try this.
I am thinking it could only be gpu or motherboard. I have a friend on the way to lend me his 1050ti and see if it works on my board, if it don't, then I guess I'm buying a new board tomorrow.
https://linustechtips.com/topic/1447010-stuck-at-vga-debug-led/#findComment-15506221
Already tried it. Same debug led.
Damn. Yeah try with another gpu
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1447010-stuck-at-vga-debug-led/#findComment-15506242
