New build MSI Meg x570 Ace motherboard, Ryzen 3900xt processor, 64 gigs corsair vengeance ram, evga 1300 watt power supply, gigabyte arous 6900xt graphics card, problem no post, error code A1, then error code 0d, cannot get into bios, no display!, help please, I am getting ready to throw my rid in the street!!!!
https://linustechtips.com/topic/1446249-help/
A1 is no graphics output (no GPU detected and no onboard graphics) I think.
0D might be RAM related.
Remove and reseat the graphics card. Check all power connections for the graphics card.
Clear CMOS
Remove and reseat the RAM ensuring it's in the correct slots if you have only two modules. Try with only one RAM module at a time.
In the future please make your thread title descriptive of the problem so people with knowledge will notice it, we get a dozen threads just titled something like "help please" per week. Also please try to write in complete sentences with proper punctuation so people have an easier time understanding you, it will make it easier to help you.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1446249-help/#findComment-15501175
Tried running 1 stick of RAM? Tried every RAM slot?
Also found someone with the same issue on a similar setup, for them it was a dead motherboard. You should do some more troubleshooting first, but I thought I'd just mention it. Also in that topic someone said it worked to disconnect the monitor for 30 seconds, and then plug it in.
https://linustechtips.com/topic/1446249-help/#findComment-15501177
3 minutes ago, Tunnlrat said:
I found my pc speaker, restarted the computer, and I get 1 long beep, 2 short beeps?
One long and two short is a display problem. See my comments about the GPU above.
https://linustechtips.com/topic/1446249-help/#findComment-15501193
1 minute ago, Tunnlrat said:
And by the way thank you for helping!!! If it is a GPU  problem, what do I do, this a brand new card 6900xt ?
Use the quote function so people know you replied to them.
Did you do any of the troubleshooting steps for the GPU I suggested above yet?
https://linustechtips.com/topic/1446249-help/#findComment-15501204
Post video when you throw it in the street,
Well, after you do what @Middcore asked.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1446249-help/#findComment-15501241
Something may be badly seated or plugged, remove GPU & RAM, reinstall, and replug all cables
https://linustechtips.com/topic/1446249-help/#findComment-15501317
5 minutes ago, Tunnlrat said:
I resetted the graphics card, I checked all power connectors, I pulled cmos battery, I even pulled the 6900xt card and replaced with a nvidia 2070 super and I get the same 1 long beep, 2 short beeps! I pulled 3 ram sticks left 1 in #2 slot I am at at loss
Try other slots, might be a dead memory channel
https://linustechtips.com/topic/1446249-help/#findComment-15501330
I have tried different pcie slots, I moved a memory stick to dimm 1 slot I finally got into the bios, it shows my western ssd that it is in sata 1 but it does not show up for an option to boot ????? I am still in bio now all information looks normal except what I mentioned above
https://linustechtips.com/topic/1446249-help/#findComment-15501420
