Budget (including currency): 1200€-1500€
Country: Europe (Slovenija)
Games, programs or workloads that it will be used for:  State of decay 2, Company of heroes 3, Cyberpunk 2077, Anno 1800, Civilization 6, Witcher 3, Mount and blade bannerlord, Minecraft ...
Other details : I am doing a completely new build for my new pc, i did some part picking myself but i have no experience as my previous PC was a pre built. So i need someone to check my build and any corrections and feedback are welcome.
This is what i pickt.
Intel Core i5 12400 6x 2.50GHz
Gigabyte B660M DS3H DDR4 LGA 1700 1xHDMI 2xDP 4xSATA3
RTX 3070 Twin X2 LHR GDDR6
1TB Samsung 970 Evo Plus M.2
Straight Power 11 Modular 80+ gold 650W
NZXT H510 Flow MidiTower black
16GB G.Skill RipJaws V black DDR4-3600
https://linustechtips.com/topic/1444863-my-first-pc-build/
If the i5-12400F is less expensive it would be a good choice.
Other than the motherboard, it's a decent build. The motherboard is ok, but something like the MSI Pro B660-A DDR4 would be much better.
You could save a bit with a less expensive NVMe drive. Pretty much any drive is going to offer decent performance in gaming.
https://linustechtips.com/topic/1444863-my-first-pc-build/#findComment-15491825
Pretty good selection of components.
The MSI Pro B660-A motherboard is the best B660 mobo, see if that fits within your budget.
The NZXT H510 has a lot of criticism for poor airflow. I would get something like a corsair 4000D airflow.
Good Luck!
https://linustechtips.com/topic/1444863-my-first-pc-build/#findComment-15491826
ok, thank you.
How big is the difference between a SATA or NVMe drive.
https://linustechtips.com/topic/1444863-my-first-pc-build/#findComment-15492213
3 minutes ago, PeytonTV said:
ok, thank you.
Very roughly if both are SSD, NVMe drive is at least five times faster. In real terms most gaming titles load 2 - 3 seconds faster from NVMe drive.
SATA SSD and low-end NVMe drives have similar pricing.
https://linustechtips.com/topic/1444863-my-first-pc-build/#findComment-15492226
ok, thx for help
https://linustechtips.com/topic/1444863-my-first-pc-build/#findComment-15492278
