Budget (including currency): ~$500-600 usd
Country: United States
Games, programs or workloads that it will be used for: School / server
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I want to use the pc as a school remote access pc but also as a server for minecraft with friends / storing data. I'll probably end up upgrading cooling in a few months, but if it becomes a problem / thermal throttles (I doubt it will) then I'll upgrade it. I'm about to buy the parts so I decided to ask a few forums for upgrades before doing so. Heres the link:
https://pcpartpicker.com/list/6KGXJM
https://linustechtips.com/topic/1444325-help-with-finalizing-pc-parts/
If the system is going to stay on most of the time, I'd do away with a SSD since you wont be loading into windows all the time (assuming it's only purpose is to be a boot drive).
I'd suggest a new cooling solution since Intel's box coolers are not that good for long term or heavy use.
I partly agree. I need a m.2 ssd because I've personally used that hard drive as a windows boot drive and, oh man it was terrible. Apart from sometimes using it as a server I need to daily use the pc for school so ¯\_(ツ)_/¯. I'm going to shell out another $100 on a noctua NH-D15 because I enjoy leaving my PC's on for extreme amounts of time (1-2 months haha) and dont want to worry about it thermal throttling lol
32 minutes ago, Somerandomtechyboi said:
Just buy a damn 4th gen prebuilt like an optiplex or something, will get you wayyy underbudget but still have pretty good performance
I mean I could. My dad said the same thing, but I already have some of the parts on hand, and I really dont want to open the back panel and find the pc engineer made pasta in the back of my pc. Also, your case is your motherboard box??? Bro r u ok
Hope it serves you well =)
$140 is extremely expensive, especially at this budget. Get some $40 case instead.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
