Budget (including currency): $730-$800 USD
Country: United States of America
Games, programs or workloads that it will be used for: Genshin Impact, Roblox, Schoolwork, (Google docs, Google Drive, Google Classroom, etc)
Right now I use a 2018 HP laptop with a Pentium processor and my Samsung Note 20 for everything. My laptop cannot keep up anymore so I decided I would look to build a computer.
As far as graphics go, On Genshin I'd like to play on low to medium settings, 1080p will work fine. For Roblox I'd like to play on medium to high settings (This can change due to the varying demands of the games on Roblox).
I am fine with buying a used graphics card.
I look forward to any suggestions.
Here's the build I've come up with
https://pcpartpicker.com/list/tTWZ9r
https://linustechtips.com/topic/1444308-build-optimization/
Pretty sure included stock cooler is enough for the i3. Save the $15 and save it towards your GPU.
Try and go for a 1660S. Shouldn't cost that much more and it'll get you more valuable frames. Also have a look out for other cards like the Vega 56 or 64. They'll get you far more FPS and I've often seen used ones sell at a similar price to 1660 cards.
The delay on cheap Bluetooth mice and keyboards will drive you mad. Instead just get something wired until you can afford proper wireless gear. Stick with something indestructible and trusted.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1444308-build-optimization/#findComment-15488687
