Budget (including currency): 8000kr-10000kr(1000usd - 1400 usd)
Country: denmark
Games, programs or workloads that it will be used for: valorant and most sort of fps games (mostly shooters)
Other details https://dk.pcpartpicker.com/list/ i made this list (or used one of the premade ones) tho i have No idea about building a pc i have a pc (2-3 yrs Old now) it seems to be running slow so im thinking of upgrading
https://linustechtips.com/topic/1443368-any-help-for-a-first-time-builder/
9 minutes ago, bmx6454 said:
the link just shows one of my builds, you need this link:
jhkhjgkgjhkghjkghjkghjkghjkghjkghjkghjkghjkghjkghurd65tuigikl.ftdyuikfkilfyuhjikdtyuklf.thumb.png.56555dc7e25fdfa4d12929c0b6e8e9b7.png
edit: also, what is your current build?
https://dk.pcpartpicker.com/guide/TydnTW/entry-level-intel-gaming-build
i Think i Got the right one? Tho theres No cpu cooler
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  (1487.00kr @ Dustin Home)
CPU Cooler: SilentiumPC Fera 5 CPU Cooler  (311.00kr @ Alternate)
Motherboard: MSI PRO B660M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  (1240.00kr @ Proshop)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (528.00kr @ Proshop)
Storage: Western Digital Blue SN570 1 TB M.2-2280 NVME Solid State Drive  (773.00kr @ Proshop)
Video Card: Asus GeForce RTX 3060 Ti LHR 8 GB DUAL MINI V2 Video Card  (3999.00kr @ Proshop)
Case: NZXT H510 Flow ATX Mid Tower Case  (678.00kr @ Proshop)
Power Supply: SeaSonic FOCUS GX 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (696.00kr @ Proshop)
Total: 9712.00kr
Generated by PCPartPicker 2022-07-15 12:06 CEST+0200
Total: 9712.00kr
Should i be worried abt this?
AM4 doesn't have much of an "upgrade" path later down the line but for some reason the b450 boards are significantly cheaper than the B660 boards.
Case should be nice and cool with 5 fans. Well performing card as well:
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (1649.00kr @ Proshop)
CPU Cooler: be quiet! Shadow Rock 3 CPU Cooler  (428.00kr @ Proshop)
Motherboard: MSI B450M-A PRO MAX Micro ATX AM4 Motherboard  (526.00kr @ Proshop)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (475.00kr @ Proshop)
Video Card: XFX Radeon RX 6650 XT 8 GB Speedster QICK 308 ULTRA Video Card  (3772.00kr @ Proshop)
Case: Deepcool MATREXX 40 3FS MicroATX Mid Tower Case  (388.00kr @ Proshop)
Case Fan: ARCTIC P14 72.8 CFM 140 mm Fan  (91.00kr @ Proshop)
Total: 9071.00kr
Generated by PCPartPicker 2022-07-15 13:04 CEST+0200
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Total: 9071.00kr
would this build be good? https://dk.pcpartpicker.com/list/hKjMTn
Board is far too cheap. you save pennies and sacrifice way more.
1000kr b660M-e is the lowest you should go.
With a 120GB storage drive you'll be able to install windows, GPU drivers and browse the web. That's it. Bare minimum 500GB SSD, realistically 1TB ssd everyone has linked you previously around 770kr.
i5 12400f can probably get away with included stock cooler. Might not even need to spend the 550kr on it. Spends 1/5th of that on a few case fans if there aren't any already.
