Hello all,
I just got a Cisco Cisco UCS 5108 Chassis for a sweet deal and we are about to start buying some blades for it (We run gaming servers on VMware)
The problem is we only have a router with a 1 GB ethernet and after purchasing this blade I am finding that the Fabric Extender Modules (See Picture) do not seem to run just plain old ethernet. I am not an expert in +sfp and am hoping someone on here can look at these three IOMs and help me find a solution to run this to my cable router via ethernet. Can I just buy a +sfp 10Gb Ethernet module and slap it into the +sfp port? It would be cool to run a fiber connection to a storage server we have as well.
As you read, you can tell I only enough about this stuff to be dangerous lol, Please take it easy on me for my lack of knowledge.
This is the IOM I am looking to buy:UCS-IOM-2208XP CISCO UCS 8-PORT 10GBE FABRIC EXTENDER EXPANSION MODULE
https://www.ebay.com/itm/265612222720?epid=150737616&hash=item3dd7b8e100:g:7d4AAOSwm2FiPOpf
https://linustechtips.com/topic/1442327-need-a-networking-guru/
You are required to use a Fabric Interconnect if you want to use the UCS B-Series servers.
You'll probably want a 6200 or 6300 series Fabric Interconnect and then you configure an uplink from there to the rest of the network.
Edit:
Almost forgot there are 6324 Fabric Interconnects which slot right into the server though which would work as you want. Otherwise you're getting a FI which is kind of like a switch but not exactly and it needs an uplink to something else to route packets.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1442327-need-a-networking-guru/#findComment-15474746
Edit:
Thanks for the reply, Yes you do need an extender to use this blade on the network, unless you buy the KVM/USB cable for the front and use a USB to NIC adapter. Hope that is not a route we end up going.
The 6324 is not a viable option, the cost of just one is way more then 4 times the cost of the enclosure.
What I was asking is about has more to do with +sfp transceivers and our normal Ethernet network.
I think the solution we will probably go with is buying this switch and cable. Still researching if this will work for what we want.
https://www.ebay.com/itm/225047978142?hash=item3465e7a09e:g:V7QAAOSwYEJivfRX
https://www.ebay.com/itm/164322728804?hash=item264265db64:g:4swAAOSwymhgOFYx&amdata=enc%3AAQAHAAAA4JdQgKIJX1GSfuGLZ0VcVh8svI%2FxXKbK0mN56VpeHApnW0U3ShtRL4d7%2BmIbGa4E5aju71iVl%2FuFct5XDm5zc4pVh8OXYebwCFAb0%2FHWcFeHecW%2BklG4LGdLE0kwUYxUdBISBalUdpE47%2Fds0nvKfDcP6PQDZDMDjt6FoOvQ%2FBQVYQy0cZrNo3ra5vk4qmLr%2B3lrcaWb3PKfR%2FxqmL54T%2FhYzNr3KWfu8FPNsApS%2BGsAQQ5NFvW09%2FOwqWDuw7yU0C%2BJMbK2UqCiPEQaVnGxZnJogPyRSUlLIS2DqX%2FyiuRZ|tkp%3ABFBMirDyn71g
https://linustechtips.com/topic/1442327-need-a-networking-guru/#findComment-15475017
That's a fabric extender which is what you need, it will NOT function like a standard switch though, you will need something upstream to handle anything else, you cannot connect regular clients to it is the main point.
Prior Build Log/PC:
https://linustechtips.com/topic/1442327-need-a-networking-guru/#findComment-15475413
