ok last year i had stock cooler min temperature was 44 C when i played game it was 85 C
and then i switched to cm evo 212 :) and temp was fixed :) min 33 C max 60 C
now summer has come again its a new year and my cpu is reaching 75 C min is 50 C
any ideas what happened ?
room temperature is 32 C
case temp is around 50 C on full load
idle temp ~ http://prntscr.com/3d84cm
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/144182-help-temp-8350/
Summer Happened
any suggestions to fix it :P
https://linustechtips.com/topic/144182-help-temp-8350/#findComment-1925375
air conditioning or more fans xD
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/144182-help-temp-8350/#findComment-1925383
already tried ac and i have the max fans i can add to the case
https://linustechtips.com/topic/144182-help-temp-8350/#findComment-1925401
you pretty much need a beefier cooler. something like a NH D14.
Unless your core is overclocked? if it is you can just step back the oc.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/144182-help-temp-8350/#findComment-1925437
or he could just get a h105 or a custom loop but more sleck and even better cooling :)
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/144182-help-temp-8350/#findComment-1925442
h105 more than sufficient  :P
I have a H105 on a 8320 at 4ghz and i keep my fans at the lowest rpm possible. i get around 35 degrees on light use while my ambient is around 30 degrees
https://linustechtips.com/topic/144182-help-temp-8350/#findComment-1925458
